Can it be done/What would be required
Discussion in 'HYBRID -> ED-EF / DA' started by DJNecrogami, Apr 5, 2008.
  1. DJNecrogami
    DJNecrogami New Member
    I have an 88 Teg USDM D16A1 (Blown Valvetrain)
    On a stand i have a JDM ZC (Bought from H-Motorsonline)
    The Mount on the D16A1 is on the side of the block
    The Mount on the ZC is in the middle of the Cam Belt
    Can i / how would i mount the ZC into the 88Teg?
    Is there a mount available?
    Thanks
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    im pretty sure it will drop right in,,they are both technically d series
  3. DJNecrogami
    No.
    The USDM D16A1 has the Engine Mount attached to the side of the Block
    The JDM ZC has the engine mount attached between the Cam Belt in the front of the block.
    NOT the same mounting location.
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
  5. DJNecrogami
    Right.
    That's ZC Info i'm wanting to know if anyone has heard of a Conversion Mount for the 88~ Integra?
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    have you done any research at all???
    because i have and the only thing i came up with is that the zc came originally in the integra,and that the zc's are identical to the d series motors
  7. DJNecrogami
    I have a D16A1 from a 1988 Acura Integra USDM
    I also have a JDM ZC Imported from Japan
    They ARE NOT the exact same engine.
    They appear to have a different mounting bracket.
    Otherwise What is the bracket on the Front of that engine?
    And are those holes on the side for the mount or?
  8. INJEN78
    INJEN78 HS LEGEND
    OHIO
    the only advice i have left for you is to put a new valve cover on that motor,,it is fuckin beat,and you obviously dont take care of your shit,or know your shit
    but have a nice day:D
  9. DJNecrogami
    It's gone now. The Acrua has been taken off my property.
    Now anyone wanna buy a 90+ ZC?
  10. 90DATeggy
    90DATeggy The Pussi Snatcher
    FL
    just drop a B16 vtec in there
  11. 92civicb18b1
    92civicb18b1 The Trisexual
    90teg, you don't read at all do you. He said ir's gone. This isn't your first retarded post either. You need to read man. I'm being nice here too,
