can someone help (revlimiter problem)
Discussion in 'ECU's, Electronics, and Tuning' started by jdmh22a, Apr 2, 2007.
  1. jdmh22a
    jdmh22a New Member
    ive just swapped in a h22a into my civic with a p13 ecu . the thing is the revlimiter kicks in at about 6800 - 6900 , im thinking this isn't right because i have seen them rev to about 8000 stock . has anybody else come accross this ? or have any ideas .
    thanks
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yea theres something wrong try swapping out the ecu and see what happens
  3. jdmh22a
    jdmh22a New Member
    yeah im trying to find another p13 . have this happend with you then ?
  4. AHHVTEC
    Alabama
    nope never happend just plug a p72 or a p30 up and see where it redlines with those
  5. jdmh22a
    jdmh22a New Member
    yeah worth a try . they are obd1 arn't they ?
  6. AHHVTEC
    Alabama
    yup, thats what i use on my h22a the only thing is the p30 will not work your butterflies but the p72 will i just took my butterflies out so it didnt matter
  7. jdmh22a
    jdmh22a New Member
    il be getting a skunk 2 inlet manifold in two weeks so that will be ok , the p30 and p72 are for smaller engines yeah ? they probably have diffrent fuel maps i expect . at least il see if it redlines higher
  8. AHHVTEC
    Alabama
    i put the p30 on mine because my p13 was for a auto tranny and i got sick of seeing the check light on, but it run fine with me
  9. jdmh22a
    jdmh22a New Member
    i got a code for my ELD thats drivin me nuts but thats about it my ecu cam off a manual
  10. AHHVTEC
    Alabama
    what code number are you having
  11. jdmh22a
    jdmh22a New Member
    does u'rs still make the same power with the p30 ?
  12. jdmh22a
    jdmh22a New Member
  13. AHHVTEC
    Alabama
    yup thats it, slap out the ecu and see if that helps it should be fine after that
  14. jdmh22a
    jdmh22a New Member
    yeah cheers il try that fucker
  15. jdmh22a
    jdmh22a New Member
  16. KuruptedKustums69
    KuruptedKustums69 V8 Killer
    i have a 98 civic hx and i just did a b16a swap from a 99 si and im having the same problem my rev limiter should rev to 8000 but mine hits at 6400?
  17. jdmh22a
    jdmh22a New Member
    its a bitch in it , im going to try what aahvtec sugested soon as i find an ecu . the car still goes like fuck
  18. pissedoffsol
    do NOT run a p30 or p72 on an h22 unless its been chipped and has a custom program on it.
    Not only do h22's have different sized injectors than the b18 and b16, the fuel maps are very wrong for it.
    If you are throwing a code, fix your code first. There is 0 use in diagnossing a rev limit problem while you have codes showing.
    ELD is wiried into the distributor wiring harness and has nothing to do with automatics, if that was the implied reference.
    trace it down and make sure its wired in correctly.
  19. AHHVTEC
    Alabama
    yup sol is right mine is chipped
  20. 91civicnut
    91civicnut New Member
    where can i find a cheap obd1 harness for a 92 1.5 vtec?
