can the coils from a 94 integra fit
well does anyone know if they fit? the suspension coils
From here-say they dont fit, Brian11to1 is right they are taller,and also stiffer due to a slightly heavier car. I was wondering tho, do the struts fit? I have a set of Tokico Blues w/ Eibach Sportline (maroon's). All for a DC I think. I am planning on taking the Tokico's off the Eibachs and putting them on my Nuespeed Races'. Will it work? Ride Quality?
DC/EG shocks and struts will work on a DA as long as you have the front drop forks from a 94+ integra. I have never heard of someone mixing and matching dc/da parts or eg/da parts, but as long as you stay with either all dc/eg or all da, you should be fine. The spring rates won;t be optimal, but then again, you may like them better than the rates that were intended for the car. Check into g2ic.com for more details on it.
