Can U Do This?
Discussion in 'Engine Building' started by 22crazy, Feb 4, 2003.
  1. 22crazy
    22crazy Senior Member
    can u put CTR pistons ( does it connect to the connecting rods?) in a gsr? and can u put a b20a5 or a3 crank shaft in a gsr? (95mm stroke) thanx
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    CTR pistons won't fit GSR rods, the B20A3/5 crank will not fit in the GSR block.
  3. 22crazy
    dam that sux....how would i get ctr pistons in a b18c1 then...custom rods...? then i guess the best crank i should go with is from a b20b or an ls.
  4. lsvtec
    Custom rods or LS Crank and rods (CTR pistons fit LS rods)
  5. 22crazy
    thanx...what about type r connecting rods
  6. lsvtec
    Same size as GSR rods.
  7. 22crazy
    oh so its because of the size the ctr pistons wont fit....i thought i was cause like the connecting rod didnt fit in the piston to hold it.
  8. lsvtec
    No, it's because the rod on the piston end is too small to hold the CTR pistons in place. ITR pistons will fit GSR rods.
