Can u upgrade to saturated injectors with OBD-0 ?
Discussion in 'ECU's, Electronics, and Tuning' started by mdixonjam, Jul 24, 2005.
  1. mdixonjam
    mdixonjam Member
    Kingston, Jamaica & Miami, FL
    Is it possible to upgrade from low impedance injectors to saturated injectors (like when going from OBD-0 to OBD-1) without actually upgrading your ECU ??
    In other words, is the OBD-0 ECU capable of supporting saturated fuel injectors ??
    Thanks
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    Yes, but you have to unwire the resister box.
    Do a search, there are like 5-6 threads with this same question.
    PS.... Saturated aren't as good as peak and hold.. so why the hell bother???
