Can you swap an F22B1 with an F22A1
Discussion in 'Accord' started by kirkhonda, Oct 18, 2008.
  1. kirkhonda
    kirkhonda New Member
    I have a 91 Accord with an F22A1. Bad smoke. I found a 94 Accord with an F22B1. Both have automatic transmissions.
    Can I just swap these out? Will they fit?
  2. Korax
    Korax New Member
    Western PA
    They will swap over, as all F blocks/transmissions are pretty much the exact same. but I think you will need the ECU plus.
  3. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    Direct swap....use youre trans and f22a1 harness on the b1.
  4. Bisimoto
    Bisimoto Single Cam Slam
    Califorina
    Youll have to wire in the knock and vtec sensors to the ecu. Bolts right in. Youll need a POH ecu, or get a P28 and get a street tune. But if you can the wiring harness for the B1 then it saves some headache down the road. If you need the pinouts lmk.
    2 people like this.
  5. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    So if he uses the b1 harness all hell have to wire is the vtec and knock from the shock tower plug to the ECU?
  6. BrutalB83
    Rochester Hills, MI
    Bisimoto joined our forums?
    SWEET!!!!! :D
  7. kirkhonda
    Will a 96 F22B1 swap for a 91 F22Ai
    I also have a shot at a 1996 accord engine. Will it fit into a 91 Accord?:confused:
  8. BrutalB83
    Rochester Hills, MI
    Yes, it will. Next time though, start your own thread...
  9. kirkhonda
    Sorry bro I thought this was my thread
    Oops I thought this was my thread. I am glad for all the info!
  10. BrutalB83
    Rochester Hills, MI
    You know what? You're completely correct! Sorry, my bad dude! :D
    But yeah, the 96 engine should work fine as well...
  11. kirkhonda
    S Series engine
    No worries.
    I am so glad to be able to tap into everyone's honda knowledge.
    Way cool.
  12. BrutalB83
    Rochester Hills, MI
    Yep, no problem man! Oh, but keep in mind that if you use the engine from a 96 it will be set up for OBD2, so you'll need to either use a conversion harness or you'll need to re-use all the accessories off of your old motor...
  13. epic860nb
    epic860nb v-tec or nothing
    New Britain Ct.
    will a tranny fit from a 1994 lx accord in to a 1990
  14. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    CB7tuner.com
  15. BrutalB83
    Rochester Hills, MI
    Yes, it will. Don't thread-jack please...
