Can't figure out my problem. So here's a VID!
Discussion in 'Civic and CRX - EF' started by nofxSOHCcrx, Apr 21, 2009.
  1. nofxSOHCcrx
    nofxSOHCcrx New Member
    Las Vegas, NV
    F**ked up car.... Video by The Jesus Of Suburbia - MySpace Video
    That's a video to what my car is doing. I can't seem to figure it out. Instead of asking over and over, I've been combing the internet for literally weeks trying to find someone with the same problem. The tach jumps around a bit, and it seems like it missfire's like a crazy. I'm not the smartest when it comes to cars, I know a bit here and there. Enough to get a by...until now. I'm replacing my IACV because I know that's no good, and without it plugged in, should just give me a rough idle, not all this lol. The problem started about a month ago, was driving down the road, and when I went to give it a good amount of gas it started sputtering and missfiring for a second, then caught up to itself and got up and went. Now it goes crazy. The main questions I have would be: Could it be my distributor? If getting a new one for a SOHC ZC, a TD02U, or a TD18U would work right? Also, could it be bad grounds causing this? Say I hit a bump, knocked a ground loose, and when under load would cause this? Any help would be appreciated. Thanks. Oh, HAHA, don't make fun of my silencer, I'm leaving it on for the REF...Oh, only code being thrown is a 14, IACV...new one coming on Thursday...Would have been today but damn Kragen sucks ass.
    Ok. No one reads after the first post lol. Replaced the IACV and Distributor. That fixed the problems in the vid. Now my problem seems to be only when I accelerate. I try to give it about half throttle and it will buck and bog like crazy, let off the gas a little, and runs like normal. The idle sounds great though. So next I'm going to replace the fuel filter, MAYBE the pump, and the Main relay also, I don't hear it going everytime I go to start my car.
  2. Crx Kid22
    Crx Kid22 New Member
    boring, oregon
    thats pretty messed up... hows the camshaft? distrbutor?are those the right plugs?
  3. nofxSOHCcrx
    Las Vegas, NV
    Yeah, they should be, everything was running just fine, then all of a sudden BAM...this shit starts happening.
  4. D16SiHatch
    D16SiHatch New Member
    sounds like you have toda vtec killer cams in there, lol. in all seriousness though sounds like your dizzy is muffed up.
  5. nofxSOHCcrx
    Las Vegas, NV
    HA...I wish. That's kind of what I was thinking, but not sure, and didn't want to go spend 1-200$ on a new one if it's something stupid and cheaper.
  6. Crx Kid22
    boring, oregon
    check all your sensors for stuff that has fallen out or come loose somethin is berzerk
  7. sevenhillsbilly
    sevenhillsbilly New Member
    isnt the dizzy for the sohc zc a td42?
  8. eg6sir
    i had this happen to my EG once.. the distributer bearing went out
  9. m90polk
    m90polk Member
    ri
    yeah I would go an check the sensors and make sure they are all fine.....also check the TPS because it can give you problems like this if the voltage is not right.....had it happen on my car, replaced all the sensors and sold the car to a guy, the next day calls me up and asks if I replaced the TPS said yeah, an he was like oh the reason it had the erratic idle was the TPS wasn't properly adjusted so the voltage kept fluctuating and caused the erratic idle. Someone posted on H.S. previously on how to propely test it
  10. TurboRex90
    TurboRex90 Golden EG
    Maryland
    You can get them on ebay for like 100$, theres a seller called the Distributor King or something but, i have a TD-42U on my D16Z6, but i had it rebuilt with MSD parts. Anyways. Good luck!
    Here:
    eBay Motors: Distributor 92-95 HONDA CIVIC VTEC TD-42U TD42U DEL SOL (item 320360438385 end time Apr-24-09 18:49:45 PDT)
    eBay Motors: DISTRIBUTOR HONDA CIVIC DELSOL 92-95 TD-42U 1.5L 1.6L (item 260394485741 end time Apr-25-09 20:05:31 PDT)
  11. nofxSOHCcrx
    Las Vegas, NV
    I think the TD42U is for the 92-95 Vtech ZC. Mines 89-91 non-vtec sohc ZC. I think I'll just replace the dizzy, and go from there...This whole thing is becoming such a pain in the ass. Just trying to get it to the ref so I can drive my car on the road again. I've had the TD02U on my car since I've had the ZC and it's ran just fine until now. So should I just purchase a new one of em?
  12. nofxSOHCcrx
    Las Vegas, NV
    TD03U 1988-1991 JDM ZC 1.6L (OBD0) Distributor
    what about this one though? TD03U. It says for first gen ZC, OBD0. doesn't say anything about sohc or dohc though. would it make a difference?
    Application Guide
    TD01U Civic 88-91 (1.5L)
    TD02U & TD18U Civic 88-91 Si (1.6L) & CRX 88-91 Si (1.6L)
    TD22U Civic 88-91 JDM B16A (Japanese Spec.)
    TD41U Civic 92-95 (1.5L)
    TD42U Civic 92-95 Si (1.6L)
    TD43U Civic ZC Engine (2nd Gen. ZC)
    TD80U Civic 96-98 (1.6L Non-VTEC)
    TD63U & TD73U Civic 99-00 Si DOHC VTEC (1.6L)
    TD31U & TD34U Accord 90-91
    TD52U Accord 92-93
    TD58U Accord 94-95 (2.2L)
    TD76U Accord 96-97 (2.2L)
    TD89U Accord & Prelude Type S DOHC VTEC H22A
    TD77U Prelude 97-02 VTEC
    TD59U Prelude 92-96 non-VTEC (2.2L)
    TD60U Prelude 92-96 JDM VTEC (2.2L Internal Coil)
    TD61U Prelude 92-96 VTEC (2.2L) & 92-96 non-VTEC (2.3L External Coil)
    TD97U CRV 99 & up (2.0L)
    ACURA Application Price
    TD03U Integra 88-89 (1st Gen. ZC) (1.6L)
    TD23U & TD24U Integra 90-91 (1.8L)
    TD44U & TD68U Integra GSR / 92-95 JDM B16A
    TD55U Integra 92-93 (1.8L)
    TD81U & TD84U Integra GSR 96-02 & JDM B18C
    TD86U & TD87U Type R 96-02 & Civic SiR 99-02
    TD85U Integra 96-98 (1.8L & CRV 96-98 (2.0L)
    Found this on another forum, figure I would post it here for searching purposes, and later on info.
  13. TurboRex90
    Maryland
    Im sorry but i HAVE to correct you on something. Its VTEC... not VTECH.. sorry.
    The SOHC Vtec motor is the D16Z6, i believe the non-vtec SOHC (ZC) is the D16Z5?. correct me if im wrong though.
  14. nofxSOHCcrx
    Las Vegas, NV
    I know, I could have swore I went and edited that...maybe I missed that one. I'm going to use that as my sig now...sohc non- VTEC zc is just the same as a D16A6, except for the cams right? I'm still curious if I should just get the same dizzy over again...the TD02U.
  15. TurboRex90
    Maryland
    A6 really?, hmm those are the pistons im looking for for my setup. Those pistons in my DOHC ZC block and SOHC Z6 head will up the compression to 9.9:1. Plus boost :)
    Didnt know it was the non vtec SOHC (zc).
  16. nofxSOHCcrx
    Las Vegas, NV
    So I bought a TD02U, and put it on, haven't started it yet though. I'm going to wait an hour for my IACV to get in, then put that on so I'm completely ready. Hopefully it will be problem solved. I'll prolly post a vid up after.
  17. nofxSOHCcrx
    Las Vegas, NV
    O.K. I put the TD02U on, and it runs WAAAAY better. I can go through the RPM range like no other. BUT....It has the same original problem. Went for a little test drive down the road, and when I go to give it some gas it bucks and bogs and doesn't want to go until I back off the pedal a bit. I can get through the RPM rangs going slower, just can't give it a lot of gas. Could this be maybe a bad TPS? or maybe even the ground from the TPS no good?
  18. yodaesu
    yodaesu New Member
    Check your ignition line including the dissy rotor, if theres no problem next bet would be the fuel line, check your fuel press
  19. phyregod
    phyregod !!YTINASNI
    Central Texas
    Sounds like the meanest NA honda build of all time! lol
    Seriously though, the cylinders are firing at completely random times, lots of them sound like they are firing after the exhaust valves are open, which could burn your valves up. Be careful with that. I'd check timing first. Make sure it didn't jump a tooth or two or something. Everyone else seems to be on the right track already though. Cap is in good shape? rotor? No cracks, pitting, melty spots, bent contact points, any of that going on?
  20. 97h22dxcoupe
    97h22dxcoupe senior member
    Coffeyville, ks.
    definately the dizzy ,replace it becuz same thing happened to my h22 vtec when i swapped it in my 97 dx i replaced it and it ran perfect,so go with that ...
