can't figure out what engine i have.
Discussion in 'Civic and CRX - EF' started by turbo sol, Nov 27, 2006.
  1. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
    i was wondering what engine i have in my rex... it's an 89 hf with multi port injection but no vtec. that and does anyone know the safest level to take the rev limiter to? limits at 5500. thanks.
  2. drew_23
    drew_23 New Member
    Charlotte,NC
  3. reikoshea
    Dallas, TX
    howd you get a 89 with mpfi...thats odd. those are usually dpfi.
    Do you have a tac in your car? If so, consider the red area the redline. I dont think the change between mpfi and dpfi is going to warrant a higher redline.
    Check the engine code on the block and get back to us. Someone might have swapped a different engine in there.
    Itll look like this:
    your engine will look SIMILAR to this one, and it will be under the upper radiator hose.
  4. eg6sir
    the 90-91 HFs are mpfi.. the 88-89 are dual points
  5. reikoshea
    Dallas, TX
    :withstupid:
    thanks bro, thats what i was getting at
  6. reikoshea
    Dallas, TX
    Thats probably chiltons talking. those are the same people that told me my exhaust manifold should be tightened to 44ft/lbs.
    hf definitely doesnt have the same engine as the si.
  7. reikoshea
    Dallas, TX
  8. turbo sol
    i'll have to go look at it tonight cause i'm at school. but the title says 89 crx and in the back tail window it says HF in big white letters. i know i have the hf trans cause of the drop in rpm between gears. i'm just as confused as y'all are...anyway i will post the numbers up later.
  9. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the stock HF engine is D15B6 and all 88-91 HFs have MPFI
    1 person likes this.
  10. turbo sol
    definately.
  11. ef8
    ef8 Junior Member
    Correct,the only 88-91 CRX to come DPFI is the DX
