cant get the bolt off
sevenhillsbilly
i cant get the bolt off of the top of my dizzy ond my d15 and i was wondering if there were any other ways of getting it off the head ??
Some have left handed threads, which means you would turn the bolt left to tighten, and right to loosen. If nothing, than I suggest what eg6sir recommended. I would say torch it until its red hot and crack it loose quickly but its risky near the distributor.
put a long lead pipe on the shaft of your socket wrench, this will give you more torque and make it a lot easier to come off
you can still put a long pipe on the wrench, and it willmake it alot easier
or cut the head of the bolt off and then just use a pair of channel locks and get the rest out.
its not that the pipe didnt work its just the head stripped a little bit after a few tries and i stopeed because i didnt want to strip it more
Use a closed-end wrench, and a really big hammer. You've just got to have more muscle than the bolt.
