cant get timing right!!!!
Discussion in 'HYBRID -> ED-EF / DA' started by tc87, Jan 31, 2008.
  1. tc87
    tc87 New Member
    hey guys i installed new cams in a b16 and i cant get my timing right... i set the crank to tdc and my cams are also lined up the notches in the teeth and red marks on top but when i started it it poped like a back fire.. so i pulled off the distributor to check that the rotor was pointing at the #1 point but its not even close, its pointing at the #2... can someone shed some light on this for me thanks
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    sounds like you are using the wrong mark on the crank pulley for Top Dead Center - the TDC mark is the one that is off to the right of the 3 ignition timing marks
