Can't Rep Over 2,000 Rpm.
Discussion in 'ECU's, Electronics, and Tuning' started by Holy_racer, Jan 20, 2003.
  1. Holy_racer
    Holy_racer Member
    Okay, I just finish my swap. I put a b16asir2 (obd1) into my 2000 civic dx hatch. I'm running obd2 with a 99-00 si ecu. I don't know why it won't let me rep over 2,000 rpm. If anyone out there know the problem please help me out. O yeah, i don't have the idle, is that the case? Or something else that has to do with the ecu? or is there something that i need to adjust or change?
    I would really appreciate any help..
    Thank you
  2. toknology
    toknology Junior Member
    lynn,mass
    must wire everything from obd1 to obd2 .skunk2 has a special harness.or try hybridgarage.com
  3. SolReaver
    SolReaver Senior Member
    [Petey Pablo, Rep Yo City] could it be the way that I be reppin (WHYYY!) for my niggaz? [/petey pablo]
  4. slammedb18acivic
    slammedb18acivic Senior Member
    pa
    make sure your injector plugs(the clips) are plugged in all the way and check all conections.
  5. Liquidblaze
    Liquidblaze Senior Member
    Huntsville, AL USA
    sounds like a fuel problem.
  6. Havok
    Havok Senior Member
    Florida
    What codes is it throwing?
