Car any good? How fast?
Discussion in 'Civic and del Sol - EG and EK' started by blwnsmke, Aug 12, 2008.
  1. blwnsmke
    blwnsmke New Member
    Ok I got the specs on the whole car today.. I think I wrote them all down right so bare with me.. Let me know what yall think of the setup and how the car should run and what kind of hp etc.. How much boost can this motor handle?
    92 CX OBD1
    T3/T4 Hybrid Turbo
    38mm WG or BOV can't remember which he said.
    B16a3
    Type R Head, Ported and Polised, 3 angle valve job,JD Springs, Ti retainers and locks, (1) JDM B16 Cam (1) JDM GSR Cam
    LS Crank
    LS Rods
    Nippon Racing Pistons (8:5.1 comp ratio) That sound right???
    Total Seal Piston Rings
    GSR Girdle
    ARP Rod and Main bolts
    RC 650cc Injectors
    Walbro 255 pump
    LS Trans with Lentex gears and a Exedy Stage 2(I think he said stage 2)
    ECU has been tuned by John Vega @ Phearable.net My buddy said something about its zipped? And the car is tuned without O2 sensors???
    Type R steering Rack and pinion
    Integra a/c
    4 wheel disc brakes
    Type r suspension front and back
    Said it has some type of really good coilovers also. Can't remember the name.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    anywhere from 100-500 hp
  3. blwnsmke
    blwnsmke New Member
    He said is has 550cc injectors. Ill have to find out exactly what the rest has done. I know I rode in it on 7psi before he put his boost controller in it and it flies!!
  4. George777
    George777 ^^ Likes Bewbies
    With your mom
    18psi on a B16? Ask your buddy what it's tuned with and who did it... From my experiences, that's a lot of boost in an already high compression motor...
  5. blwnsmke
    blwnsmke New Member
    Is it possible that the pistons he changed out are like a dome pistons to lower compression?? I was looking at the downpipe and noticed the O2 sensor wires were cut off.. I asked why, he said if its tuned good enough then the 02 isn't needed.. Sound right?
  6. AHHVTEC
    Alabama
    the primary o2 sensor is always gona be needed
  7. efhondakid
    Akron-Canton, Ohio
    Dome top pistons dont lower CR, and not needing a O2 sensor? :bs:
  8. phyregod
    phyregod !!YTINASNI
    Central Texas
    Yup, that motor can't possibly run at its best with no sensor.. That much boost with 550cc injectors and an ecu stuck in limp mode because it has no idea how its running is just a bad deal all together. Could be damaging the motor by running it too lean, could be all clogged up with carbon buildup by running rich.. Thing is, the ecu just has no idea so its dumping fuel one way or the other.. usually rich in limp mode, but I don't know how rich its going to be with boost on it.
    Tell him to get the o2 sensor fixed, do a compression check on the motor, and hope for the best.
  9. BrutalB83
    Rochester Hills, MI
    Ask him what it's tuned with, and ask for more details on the engine build...
  10. blwnsmke
    blwnsmke New Member
    Bump.. I got the car specs updated up top.. Check em out
  11. blwnsmke
    blwnsmke New Member
    What could I do to build this motor to be faster but still reliable?
  12. AHHVTEC
    Alabama
    well to start out i think you should go have it dyno tunned to see what you have, or could get out of it like it is
  13. George777
    With your mom
    My suggestion is to start your own build. Don't take on someone else's headache. If you want it faster, build it that way. Run the crap out of that motor until it blows, and then go from there...
  14. blwnsmke
    blwnsmke New Member
    Is this a good setup?? How much boost can I run on it? He just built the motor not long ago so it doesn't have many miles on it..Im COMPLETELY new to the import scene so thats why I asked what I could do to make it faster.. So say if it did blow one day, whats something I could do to make it faster using that turbo setup and same injectors and fuel pump.. Is there a better head I could swap? What about block?
  15. AHHVTEC
    Alabama
    the setup sounds fine but theres no way of knowing what your asking, your gona have to go get it dyno tunned
  16. George777
    With your mom
    CRVtec with boost...
  17. blwnsmke
    blwnsmke New Member
    What is the CR? I understand the Vtec part..
  18. George777
    With your mom
    CRV (B20) block with a B16 or B18 vtec head... Also known as a Frankenstein swap...
  19. blwnsmke
    blwnsmke New Member
    Its a b16a3 block with a type r head is what the car has.. What does the type r head come off of orignally?
  20. George777
    With your mom
    Civic Type R (CTR)...Unless its an Integra Type R (ITR)...
