Car dies at idle and at times no start
Discussion in 'HYBRID -> ED-EF / DA' started by Jayamashey, Jan 23, 2007.
  1. Jayamashey
    Jayamashey Junior Member
    '89 Civic SI with B16A2
    - steady idle at 500 RPM
    - timing is good and not gettting any codes
    Car ran fine until 2 days. I was driving it and at a stop light it just died then I started it up again no problem.
    Then today I went to start it and it wouldn't start. After waiting about 20 minutes it deciced to start but kept dying at or near idle and would want to start. I could only run it with the gas slightly pressed. After i got home it idled fine and didn't die.
    Any idea's whats causing this?
  2. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Hmm... Are you throwing any codes?
  3. klyph
    klyph Dismember VIP
    North Pole, AK
    Something tells me no.
  4. Andrew
    Tallahassee, FL
    Haha... reading>me
  5. 801CRX
    801CRX Got Rice?
    UTAH
    Electrical?
    maybe the altenator?
  6. Jayamashey
    That doesn't explain the no-start after it dies. Plus battery has full charge. I was questioning if it could be fuel pump - but I don't feel fuel cutting out.
    Plugs and wires are new. And since its at idle I don't think its the dizzy.
    This problem is baffling me.
  7. Jayamashey
    Turns out it was the ignitor chip - I luckily had one from an extra distributor.
