So every time I press my clutch in to stop at a stop light my engine RPMs drop down to 200 or the car dies all together. It only happened after the car warms up and it starts right up after it dies. I've replaced the Idle control valve with a known good one and have played with the idle screw to see if that would work. the mods on the engine are as follows:
B16 bored to 84mm with Golden eagle sleeves
CP 9:1 comp pistons
eagle rods
ported B16 head
duel valve springs w/ titanuim retainers
GSR cams
type R intake manifold w/matching throttle body
The engine has less then 4,000 miles (never raced) on it after a trip to the machine shop and fresh rebuild. It is turbo'd at the moment, hence the 9:1 compression. Tuned with Crome
I'm at a loss
CP 9:1 comp pistons
eagle rods
ported B16 head
GSR cams
I'm at a loss
