MarkJimenez99
Hey guys. I just installed a brand new clutch, Throwout bearing and pressure plate. I also had to replace the drive axle because it was broken. After doing all this, I finally got a chance to test drive my car. It was working for awhile until I reached a hill.
I shifted into first gear and released the clutch. I heard something come out when I did this. Now I can't move again when I shift into gear. The car is still running and I don't hear any noises.
Everything sounds normal except that I cannot move. The pedal pressure is fine and I checked the clutch slave reservoir and it's still full.
Do you think it has anything to do with the clutch? I don't even hear it trying to engage anymore. :unsure: Or could it be the axle? Maybe it's not in all the way? It's not making any noises.
Any more ideas of what the problem could be? I would appreciate your help.
