car dont move
Discussion in 'General Tech and Maintenance' started by mygsr, Mar 24, 2006.
  1. mygsr
    mygsr Member
    LOS ANGELES
    hey i just finished fixing my gsr from a wreck i had to buy a new tranny and other parts but the engine is still good after about 6 month the car started and sounds great my problem is i had to put a new tranny the car starts you can hear the gears go in but the car doesnt move? what could it be? any help would be appreciated
  2. vanillakilla
    vanillakilla Senior Member
    Tacoma Washington
    what the hell do you mean it won't move like you engage the clutch and it dies I have never heard anything like this before [​IMG] :cry2:
  3. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    If it goes into gear, and sounds like it should be normal (not grinding all over etc),
    your clutch is gone.
    (Out of curiousity, try putting it into 1st gear without pressing the clutch pedal at all..)
  4. mygsr
    mygsr Member
    LOS ANGELES
    yea h i push the clutch and shift it to fisrt and i let go the cluth but it doesnt move all the gears sound like they go in
  5. FFCiv
    FFCiv Senior Member
    you probably forgot to put in a clutch
  6. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    that or try checking your axles and make sure they are all the way in. I know for a fact the car won't move if only one axle is in correctly.
  7. Contender
    Contender Junior Member
    I also know "just for reference to everyone" that if the axels are wrong and do not fit right they will just spin and not move in gear.
  8. pageusaf
    pageusaf Senior Member
    Pittsburgh, PA
    have a friend look over it for ya, some times another eye can spot somethin you missed..... other than that seems like everybody named the shit i would have said already
