car don't start AGAIN!!! --__--
Discussion in 'Integra' started by jiajiexue, May 28, 2007.
  1. jiajiexue
    jiajiexue New Member
    after i change the the fuel pump, car dead on the freeway while i was driving.
    take 15 mins to start back up again, then died again right in front of my house.
    i change distributor cap rotor, spark plug wire spark plug couple weeks ago, what else could be wrong, stay online waiting for you guy's advise!!!!
    thanks so much
  2. jiajiexue
    i just change the the WHOLE distributor today. still couldnt fire up, before i change the distributor, my friend tested and said i dont get any spark?
    what else coudl be wrong?
  3. 99sidude
    Ohio
    check your grounds
    also check your main relay
  4. jiajiexue
    which grounds you talking about???? i heard my main relay operated when i turn the key on, still could be that?
    i mean could it be the starter? it;s cranking tho!
  5. 99sidude
    Ohio
    the ground wires running from your engine to your chassis. There is one running from the valve cover, and another 1 or 2 coming from around the starter. Are you sure your main relay is good? check for fuel pressure.
  6. eg6sir
    if the grounds are bad, it wont even turnover..
  7. 99sidude
    Ohio
    that is correct
  8. eg6sir
    he said it was cranking, so grounds aren't the problem
  9. jiajiexue
    how do i check if the main relay is bad
  10. eg6sir
    see if a friend has one you can borrow to test it out.. that way if its not the problem, you dont waste the money on something you dont need..
  11. jiajiexue
    yeah, but if it;s bad main relay, will it the car die on me WHILE i was driving?
  12. eg6sir
    yes.. that or it wont even start
  13. 99sidude
    Ohio
    heat is known to accelerate the failure of the main relay. When mine started to go bad, the car would just crank and crank after i drove the car for awhile, turned it off, then tried to restart it after a few min. Eventually the car wouldnt start because the relay quit entirely. Check to see if you are getting fuel pressure (an easy way to check is to loosten the bolt on the fuel line going into the filter. Try to crank the car, but only for a second. If you have fuel pressure, then gas will squirt out of the loostened fitting. If you have fuel pressure, diagnose spark delivery, if not, pull the main relay, and use a jumper wire between the pin 5 and 7 on the connector. Again, do the fuel pressure test i highlighted earlier. If there IS fuel pressure, then its the relay thats bad, if there still isnt pressure, the fuel pump may be toast.
  14. 99sidude
    Ohio
    IDK if a bad relay will cause the car to die while driving. That never happened to me though.
  15. jiajiexue
    yeah, mines deads on the freeway while i was driving , and then took me 15 mins to start back up, and then dead again right in front of my house , like idel drop to dead. couldnt start afterwards
  16. TAGURIT
    TAGURIT New Member
    main relay or fuel pump relay may be going bad.
  17. jiajiexue
    i know hwere the main reply at,
    anyone know where the fuel pump relay at?
  18. TAGURIT
    TAGURIT New Member
    its under the dash
  19. jiajiexue
    so there are really two relay!! one is main relay, one is fuel pump relay
  20. TAGURIT
    TAGURIT New Member
    my da has one....
