car dont want to turn on some times
Discussion in 'RSX' started by carlitoswaypr, May 4, 2008.
  1. carlitoswaypr
    carlitoswaypr New Member
    BRIDGEPORT CT/ PUERTO RICAN
    my RSX S dont want to start some time like if it dint have gas... my uncle told me is the fuel injection but i put in gas tank LUCAS fuel injector clening but it has been 4 day and this morning did it again ???:wtf:
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    does it start ? or does it just take a few seconds before it fires up.
  3. carlitoswaypr
    it starts after i try for like 1 min.
  4. AHHVTEC
    Alabama
    if it takes that long for it to start it sounds like the fuel pump might be trying to go out
  5. carlitoswaypr
    the fuel pump ,, what you mean trying to get out :mellow:
  6. AHHVTEC
    Alabama
    what i mean if its taking that long to start you having a fuel or spark problem,
  7. carlitoswaypr
    i did a tune up and change the spark plug but it still do it
  8. carlitoswaypr
    and how much to fix or change the fue pump and it hard to do ????
  9. AHHVTEC
    Alabama
    you sure are having a lot of problems with this car, if you here the fuel pump come on when you turn the key on its prolly fine. do you have any check engine lights on
  10. carlitoswaypr
  11. carlitoswaypr
    hey i was thinking . maybe is because the guy that had it, he use to put premium gas. and now im puting regular because the price is to high... maybe is that because i ask him if it use to do it when he had it and he told me no....
  12. AHHVTEC
    Alabama
    umm yea dont do that it says right on the gas lid premium gas only
  13. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    I agree. You dont want some shitty gas with a high compression NA motor like that. Switch over to some premium and see if that helps any. You can rule that out as a problem untill you take care of that.
  14. awptickes
    MD
    Heh. My car ran like shit when I got it, because my dad filled the tank with regular before he gave it to me.
    Switch to premium, and/or flush the tank before you detonate and break a rod.
  15. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    That engine is designed for 87 octane pump gas, running premium isnt going to affect its starting. Your problem isnt a fuel pump. How often do you see type-s' needing a fuel pump/sending unit? Never, especially from factory. Your problem is most likely a starting/charging system issue. Also, make sure your plugs are at the correct gap and that the spark plugs are snug in place and not loose.
  16. 90DATeggy
    90DATeggy The Pussi Snatcher
    FL
    also make sure u got a decent igintor throwin out some good spark my da is acting the same way ur car is sounding its my Dizzy, and if u do need to changed the fuel pump..all i say is good luck when my walbro went out on my ass it was a funny 4hrs of work (no jacks to help)....but good luck
  17. AHHVTEC
    Alabama
    the k20a2 motor was not meant for 87, it needs 93 or better
  18. carlitoswaypr
    fuck .. gas is not cheap no more man . its no joke over here is at 3.99 reg
  19. AHHVTEC
    Alabama
    no gas is cheap even 87 but id rather pay the extra than mess my car up
  20. carlitoswaypr
    true .. but what could happen if i keep gettin 87??????????????????
