K, Im guessing head gasket, but I figured I would ask for a second opinion.
My car used to heat up on highway trips, going about 60 at 2k RPM for about 15 minutes would start heating it up and would continue until I turn on the heater, which it quickly drops afterward. Now it is heating up almost every time im in 4th or 5th for more than ten minutes. (ie long deliveries)
It also used to turn the fan on rather infrequently and now its probably on 60-80% of the time.
I also have a rough idle which could be attributed to a vacuum leak (<-- could that be from a head gasket?)
I tested the compression about a month ago and it was fine in all but #2 (which was 90)
Thanks in advance
Thanks in advance
