Car idles real high
Discussion in 'General Tech and Maintenance' started by Apocalypse, Feb 24, 2004.
  1. Apocalypse
    Apocalypse Junior Member
    Just like the title says. Swapped a B16 SiR 2 in my 5th Gen Civic and it is idling REALLY high. How do I go about fixing it? Thanks in advance for the help B)
  2. E_SolSi
    did you just swap that engine in???
    have you let it run long enough to fully warm up???
  3. Apocalypse
    Warms up and idles at around 1200 rpm <_<
  4. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    intake manifold gasket? just an idea- that made my lude idle high for 3 monthes and then it ended up causing a real irratic idle- just an idea though!?
  5. highperboi
    highperboi Senior Member
    Alameda, California
    tighten the idle screw all the way? check for loose vacume lines?
  6. Apocalypse
    Have a spare IM gasket, so I might put that on if nothing else helps since it can be kind of a PITA. Where's the idle screw? All my lines are hooked up. There's a line coming off the PCV valve that has nowhere to go, though. <_< I looked and looked and couldn't find somewhere for it to go....any ideas on that?
  7. highperboi
    Alameda, California
    the idle screw is on the throttle body. hmm dont know about the pcv vlave tho.
  8. CRseX84
    CRseX84 Senior Member
    SUNY Canton College, NY.
    yea my boy just swaped a GSR into his G2 and his idles at like 2,500 and he relized a few vac hoses were in the wrong place. get a vacume hose diagram. and make sure ur hooked up right. good luck
    Tyler
  9. hybrid89
    hybrid89 thistownsucks...
    SoCal
    also check the tension on the throttle cable. If it is even a little too tight, it will open the TB just enough to fuck with your idle. just another idea. 1st place I go cause its the easiest fix.s. would be vacuum lines.3. Intake manifold/gasket.
    matt
  10. Apocalypse
    Ok, I'm not throwing any codes except my O2 sensor code <_< But anyway, I unplugged the IACV, revs went down to about normal, but it isn't throwing the code. Hmm. About the bypass screw, I don't see one anywhere on the TB. Could it be because I had to use the D-series one, or should there be a screw on there, too? The throttle cable is fine, too. About the vaccuum lines, does anyone have a diagram?
  11. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    fix the o2 sensor.
    and its not the IAC valve.. the idle screw is brass and it is on d series throttle bodies also..
  12. Apocalypse
    Well, I replaced teh o2, but it's still throwing the code, so I think it might be the piggy tail or whatever the hell you call it that plugs into the o2. Know anywhere I could get just that without having to buy a whole new harness? o2 sensor wouldn't cause it to idle that high, would it? Thanks for the help, guys. B)
  13. swanny
    swanny Senior Member
    buck teeth and government checks, PA
  14. Accordturbo94
    Accordturbo94 Senior Member
  15. aznboysrfr
    aznboysrfr Junior Member
    Aliso Viejo/Laguna Niguel, Cali
    check your spark plugs ... if they are too loose or too tight, it'll idle funny ... mine stock motor idled at 1800 until I found out what was wrong. Kinda strange starting in 1st gear without having to press the gas :huh:
