JDMSpecAccordSir-T
Member
Ok here the rundown. I had a problem with my throttle sticking right so I worked up the courage to take off my TB (BTW I have a F20B TB, its the same as the H22A) and when I took it off i was like WOW. It had a lot of grease and sooth in it. So i took the throttle plate off and cleaned it throughly with H7. Next i did the TB it self (I just used a rag with H7 on it and cleaned it off).
I noticed some coolant coming out of one of the lines I took off the TB.
Anyways I hooked back up all the lines and tightned back up the nuts and bolts and tyed to start it up. Now the engine wont idle unless when i start it up i press on the gas and then it goes up and down and if i try to floor it it just dies (the engine is warmed up).
I triple checked the lines and sensors and they are good. The MAP (black one) sensor has the one with the blue plug and the other green one (???) has the grey plug in it (its a 1998 so i guess i have a OBD2 ECU) and the vacuum and coolant lines are in the right place like it did before i pulled it apart.
I also dont see any CEL so im pretty sure I didnt switch around the plugs
Ive heard people talking about idle adjustment but i dont know where the screw is for it?
PLEASE HELP
PLEASE HELP
