civtegra07
I have looked around this site and i can't find anything that is close to my problem.(I think). I have an 89 civic dx. I swapped a d16a6 into it with all si wiring. Now after days of trying to start it, it finally ran on its own. I let it run for about 5-8mins. I tried giving it some throttle and the car will not rev past 2000rpm. Now it sounds a little ruff. So i shut the car down. Waited a bit. Started the car again...now the car will not idle on its own. I have done a compression test(right after i let it run for the 5-8mins.) the results were #4-185 #3-180 #2-175 and #1-190. so my knowledge leads me to believe that the head gasket must be descent. So my questions are: 1. Why will my car not rev past 2k and won't idle on it own, and 2. i have oil coming from the front left corner of the head, and the front right corner behind the timing cover.(where the head meets the block) Please help. Any reply will help me. thank you very much. Oh i will try to send the video of the car running so you can hear what it sounds like.
dany
dany
