Car not starting after heavy rain question
Discussion in 'General Tech and Maintenance' started by wikedeye, Sep 27, 2010.
  1. wikedeye
    wikedeye Well-Known Member
    Savannah, Ga.
    A couple of weeks ago it rained really hard and my car would not start. The next day when it was dry it worked with no problems. This morning I go out after a heavy rain and again no start. I know that it is probably condensation or some form of moisture that is causing the problem. When this happens the engine cranks, but the fuel pump does not come on. Is the problem most likely in the fuel pump or main relay? How do I check to see what is getting wet? Could there be any other culprits?
  2. skimboard71104
    skimboard71104 New Member
    jersey
    Try the distributor cap. that same thing happened to mine and i bought a new cap with bolts and everything put it on and i haven't had a problem since.
  3. wikedeye
    Savannah, Ga.
    I checked the distributor and it is dry as a bone. So is most of the engine bay. The thing that I notice is that the fuel pump does not turn on. I know tomorrow when it is dry and sunny it will start up. I just want to try and fix the problem before it happens next time. Is there any part of the fuel system from the main relay to the pump that is prone to water exposure?
  4. skimboard71104
    jersey
    Honestly idk man that was what was wrong with mine if i were you i would check the whole fuel system.... like the fuel pressure service fitting, throttle body, IAC motor, fuel rail, fuel pressure regulator, distributor, air cleaner housing, fuse and relay control system. thats what i would do.
  5. wikedeye
    Savannah, Ga.
    I appreciate your help, but it has something to do with either the main relay or fuel pump. Unless there is anything else that can keep the fuel pump from turning on.
  6. civichatch1988
    civichatch1988 Ef hatch
    Seattle
  7. wikedeye
    Savannah, Ga.
    Yeah I will tomorrow. Could bad weather stripping be the culprit? Maybe its letting moisture in.
  8. civichatch1988
    Seattle
    Anything is possible when is comes to moisture and electroncis lol, your best bet would to be testing things with a multimeter when the car is doing this to check for loss of power anywhere. Basicly your gonna have to do process of elimitation weather you like it or not
  9. wikedeye
    Savannah, Ga.
    Hopefully it will still be doing this tomorrow when I have time to test it.
  10. wikedeye
    Savannah, Ga.
    The car is still not starting after two days of sun. I checked the main relay which checked out ok. I got a new one anyway and still nothing. I checked for voltage at the plug. Continuity was good on the black wire. Yel/Wht had 12.5 volts. Blk/Yel had 12.5. Blu/Wht only had 10.4 volts. Is 10.4 normal or should it be higher? I checked the fuel pump by jumping the plug and it comes on. The pump does not come on with the main relay connected. What else could it be?
  11. wikedeye
    Savannah, Ga.
    Does the ignition switch have anything to do with the main relay getting power?
  12. civichatch1988
    Seattle
    I believe so, when key is on pos does the fuel pump kick on to charge the lines?
  13. wikedeye
    Savannah, Ga.
    No when the key is on with the main relay plugged in then there is no action at the pump. If I remove the relay and jump the plug it comes on. I have the old relay that is good and I got a new one just to be safe and neither work. All the fuses are good. There is voltage at the relay plug. The blu/wht wire from the ignition is only reading 10.4 volts. The others read 12.5.
  14. jamesA
    As well as your battery cables and connections. Just had this problem on my work van. Wouldn't start for a day because the battery connections were loose. It was odd because when all the accessories come on but it won't crank, you wouldn't think to check the battery. But it'll be the simplest thing to look at in your case.
  15. wikedeye
    Savannah, Ga.
    I have checked the battery as well as the ground to the thermostat. I just checked the map sensor plug and the pink/wht wire had 2.8 volts and the yel/wht (I think) had 3.3 volts. I have read that I should have 5 volts to these wires. What does the voltage being low indicate? I can hear the main relay click when I turn the key to the on position.
  16. civichatch1988
    Seattle
    this is beginning to sound like an issue i had once, don't quote me but my pump wouldn't come on either and when i ran direct power it would.. get an ecu pin out check for power at the wire where the fuel pump connects to the plug for the ecu. if no power trace it back. im petting on bad grounds or pump
  17. wikedeye
    Savannah, Ga.
    When I jump the main relay plug the pump comes on so doesnt that mean that there is power getting to the pump? I am more concerned with the fact that there is less than 5 volts at the map sensor. I am going to start checking the ecu. I am really getting worried that the ecu has a short or something.
  18. wikedeye
    Savannah, Ga.
    Ok so I went back through all the tests. Fuses are good. Relay is good. Pump is good. Map sensor shows .33 .28 volts, I was wrong before when is said 3.3 and 2.8. So I tested the ecu everything points toward a bad ecu. All the wires have voltage where needed and there is continuity in all the right places. I ran the trouble shooting flowcharts from the helms and they keep saying "substitute known good ecu". Will any p28 work or does it have to be one that has been chipped? What other ecu's could I use to test with?
  19. E_SolSi
    should start up on any P28
    have a friend with a known good one you can swap out for to test?
  20. wikedeye
    Savannah, Ga.
    Yeah I have been trying to think if I know someone that has one. I know a guy here that has an integra gsr, and I know a guy that has a ls/vtec swapped del sol.
