car opinions?
Discussion in 'HYBRID -> EG-EK / DC' started by tegg_gsr, Sep 12, 2003.
  1. tegg_gsr
    tegg_gsr Member
    i own both a 95 gsr with 165000 miles on it, and a 92 vx i was thinkin about sellin my gsr and buying a complete swap from hmo.com.or maybe i should just take the motor out and build it up then swap it into the hatch then part the gsr off and sell the stock vx motor and tranny. Just throw some opinions at me. Thanx
  2. tegg_gsr
    tegg_gsr Member
    anybody, any opinions, anything?
  3. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    well a GSR powered EG vx is a great starting point for it's power and weight..
    I say go that route.
  4. tegg_gsr
    tegg_gsr Member
    well you mean take what i have(95gsr) and swap it out instead of buying from hmo ;right?
  5. tegg_gsr
    tegg_gsr Member
    1)when you get an engine from hmo is there any way of telling how many miles is on any way? 2)i plan on putting a turbo on it and i was wondering since i have all those miles on it what do you suggest i do to run it safely on a everyday driven car?
  6. NoJokE
    NoJokE Senior Member
    1)There is no way of telling the mileage, but there are signs. Do a compression and leakdown test to see if it burns oil. 2) Fuel management, fuel management, fuel manegement
  7. tegg_gsr
    tegg_gsr Member
    im tryin to get somewhere in the mid 13's (to beat my girlfriends car )so do you think i would be better off going all motor since ive got i/h/e already?i know i would have to get a different exhaust already to fit the hatch . ps. im on a budget!
  8. NoJokE
    I thought you were turboing it? Drop it in the vx and you will drop a couple of tenths, since its a lot lighter then the teg.
  9. tegg_gsr
    tegg_gsr Member
    so from 15.45(gsr) to around 15.25(vx) sumthin like that is to be expected from this swap?
  10. mariowc
    mariowc Junior Member
    Littleton, CO
    Yea, I'd say safely you could be running pretty much low to flat 15's with that motor and no mods. (Intake and exhaust are NOT mods either... :D). Check out the turbo or supercharge route will be the only way... you can try N/A, but that will get expensive REALLY quick and you may shave about second off your time if you do a decent mild build up.
  11. JDMilan
    Boca Raton, FL
    Sell your GSR CAR...keep the VX.
    Now since you want to top 13.45... I would suggest buying a nice J spec ITR motor.
    As for a great parts list:
    Comptech icebox
    SMSP/Toda2.5 header
    Test Pipe
    2.5 mandrel exhaust with your muff of choice
    P28 ecu with ITR base map and Hondata
    15inch light (less than 12lbs) rims with good rubber
    Jun/Toda/Spoon/Fidanza flywheel
    Whatever clutch you want
    Cam gears from Jun/Toda/Spoon
    that should get you there for sure with practice and it's reliable.
  12. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Hell man, sell the GSR as a complete car, and you should net MORE than enough to drop an ITR, GSR whatever with plenty of bolt ons maybe even a boosted LS. Since B's run around mid 14's to high 13's in stock trim in a hatch you will be just short of your mark, spend some time perfecting your driving, goal met.
  13. tegg_gsr
    tegg_gsr Member
    well iwas gonna boost an ls/vtec but it seems you really have to know what your doing to get it done right.and ive heard they dont last.and i also read that if i drop an h22a w/ bolt ons i might be able to get in mid to high 13's.my dads a mechanic. he does swaps just about every other day so i know he wont have a prob with swapping for me.
  14. JDMilan
    Boca Raton, FL
    sounds like you want boost, sell your GSR Car complete.
    Buy a GSR motor throw that in, turbo kit, tune it out to 8psi so that it runs nicely and you have a great ride, then when more money comes upgrade the otehr stuff.
