Car rolling forward??
Discussion in 'General Tech and Maintenance' started by Jazzy19, Sep 7, 2004.
  1. Jazzy19
    Jazzy19 Senior Member
    Hey guys,
    I have a slight problem.. 97 GSR, the whole car is stock with 70XXX on it.. When i pull upto a stop light and take the car out of gear.. The car still moves forward like its in gear.....im in neutral and the car still moves forward.. Even when i step on the brake and release it, it moves foward...
    1. What is causing this??
    2. Is this a sign of the clutch going bad?
    3. How can i fix this problem???
    Any input would be a great HELP!!!
    THANKS,
    JAZZY 19
  2. driverunknown
    driverunknown Senior Member
    Are you on a slope?
    You don't make any sense. When you are in neutral is the clutch still pressed in? Or can you put it in neutral and take off with the clutch like its in gear? Explain yourself more.
  3. Jazzy19
    My bad..... Well im on a flat road surface...The clutch is not pressed in...Like when ur car is sitting after u turn it off!!!!.. This rolling happens when i stop @ a light and put the car into neutral, I've taken my foot off of all pedals and the shit is still rolling like if my car was in gear..... Now i could go into more detail but thats the core of the problem.... SO do u think you could help me now????
  4. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    maybe the clutch isnt fully disengaging.
  5. MXDesa
    MXDesa Senior Member
    Queens, New York
    Well hes in neutral so if the clutch wasn't fully disengaging, that wouldn't matter cause hes in neutral. How much is it rolling? is it inching forward or straight up rolling like its in first gear? Describe it more because even if it seems that ur on a level surface its still normal to role a little
  6. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    the clutch wdn't cause that cause he has the car in neutral.
  7. Jazzy19
    well lets put it like this... If i stop completely stop behind someone and put the car in neutral and take my foot off the brake i will slowly run into the back of the other car.. I would say it rolls like 10-15inches??
  8. MXDesa
    Queens, New York
    Dont worry, my SI rolls also its normal to do so
  9. ludegirl
    ludegirl Senior Member
    Southern Cali
    maybe its those dead school children from mystery hill
  10. K2e2vin
    Raleigh, NC
    oops didnt read the neutral part.
  11. Jazzy19
    so is anyone have a solution.. I know Standard cars are suppose to roll abit.. but this is alittle too much rollin
  12. 4short
    4short Member
    does it roll if your at a stop and have the clutch pushed to the floor? if it does not then your clutch is not disengageingall the way take it to a shop and have them bleed it
  13. 92civicb18b1
    92civicb18b1 The Trisexual
    You have to be on a slight incline, it is impossible for the car to move with no force. It is also impossible to have the transmission or engine rolling the car if they're working properly, even so if you took your feet off of all pedals and it was still in gear you would stall. So the only logical thing is an incline.
    Did you just learn how to drive stick or at all?
    BTW the way your making it seem is some unknown force is pushing you (this is called gravity). Think of it like this your car is a cue ball when it's in nuetral and it's on a completely flat surface on a let's say 8* angle, it's going to roll down, it's physics.
  14. K2e2vin
    Raleigh, NC
    i was thinking it could probally be friction in between the gears, so when the shift fork disengages the gear, the gears are probally rubbing or something.
  15. 92civicb18b1
    Still impossible I think, I don't know much about the gear sets but I don't think it's possible. I really think it's an incline. All of our cars do it, they always will unless gravity somehow dissipates or something.
    Physics don't lie.
  16. Jazzy19
    Trust me ITS NOT A INCLINE... I KNOW WHAT A INCLINE IS.... AND I KNOW HOW TO DRIVE STICK.... I was thinking maybe something with the gears or clutch cuz when i take my foot off all pedal and im on a straight road.......it Rolls, even from a dead stop it will roll pretty fast... The clutch pedal is not pushed down to the floor... Could it be the idle thats too fast....
  17. driverunknown
    Have you recently had any work done on the car. This thread is too funny.
  18. brian11to1
    brian11to1 Senior Member
    maybe hte clutch is out of adjustments
  19. Jazzy19
    I know.. This is really funny shit... How would i go about adjusting the clutch??? So far that sounds like the best answer yet.....hahaha... I didnt know that this was a hard thing to fix....
  20. SolLess16
    SolLess16 Senior Member
    Will the car keep on rolling on a strait plane for miles?? or does it only roll for a certain distance?? when the car is rolling rev it a little bit and see what happens. also when your rolling push the clutch in and also see what happens
