Car Shakes..... Help
Discussion in 'General Tech and Maintenance' started by b18delsol, May 17, 2004.
  1. b18delsol
    b18delsol Member
    My Del sol is shaking when i am in the 55-65 mph zone. anyone have any idea why it is doing that?
  2. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    Tires need balancing, alignment...the list goes on. Check the tires first.
  3. pissedoffsol
    yeah most likely a wheel/tire out of balance
  4. tlb1127
    tlb1127 Banned
    Also check the axles to see if there good or not. My boy had that problem and it was the axles. TRY IT OUT
  5. B16
    B16 Super Moderator VIP
    yay area, CA
    and this is not an engine building question.
    :moved:
  6. b18delsol
    b18delsol Member
    If it is the axles or tires why is it only doing it between 55-65 mph
  7. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    Think of it this way. You are swinging a weight, tied to the end of a rope, above your head. The faster you spin it, the more force you need in order to keep it from slipping out of your hand. This force is due to centripetal acceleration. Same thing happens with an imbalance in your tire. Only the force is transmitted via vibration. Same thing with the axles if the bearings are shot.
  8. adnoh
    adnoh Senior Member
    Ontario
    Also due to the fact that the majority of the wheel balancing machines out there dont go over 50mph. When I worked at Honda, we had one that spun way faster, which had better results.
    Try and find a place that sells performance wheels and tires and also does balancing and alignment and such. They will be more likely to have a faster spinning balancing machine, which will help you out with your problem.
    That is.....if this is actually the problem.........
    Check all the other stuff as well.
