car starts....usually
Discussion in 'HYBRID -> EG-EK / DC' started by henshinJDM, Jun 2, 2005.
  1. henshinJDM
    henshinJDM Member
    Northern Indiana
    just swapped motor 2 weeks ago, everything went great no problems and turned key and it fired right up and runs great
    but once in a while, when i turn the key....nothing, all dash lights are on and everything, its got a new alternator so im guessing that shouldn't be the problem
    could it be just the battery? starter? wire?
    thanks
  2. wannaberacer
    wannaberacer Member
    my guess is the wires to the starter are loose
  3. henshinJDM
    henshinJDM Member
    Northern Indiana
    thanks for the input, believe me ill check it out, i travel alot and ive got to get all the "bugs" out before i drive to far from home.
    i guess if all else fails and it ends up being the alt. its got a 1 year warranty, but its a pain to pull it!
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Sounds ok, could also be the ignition.
  5. henshinJDM
    henshinJDM Member
    Northern Indiana
    :D yea, umm....the ignition switch is bad, do you know if i could use the switch from the integra? i know the keys would be different, but would it fit? its free if it fits
  6. henshinJDM
    henshinJDM Member
    Northern Indiana
    fixed it! the engine ground wasn't quite tight enough. i was stranded for a while and couldnt fix it, then i tried that and it worked on the first try
