car STILL smoking
Discussion in 'General Tech and Maintenance' started by b16coupe, Jul 7, 2005.
  1. b16coupe
    b16coupe Senior Member
    anderson, S.C.
    I just got done changing my valve seals and my car smokes really bad but not out of the exhaust. It comes out of the valve cover and it looks like it comes out of the back of the motor too but i can't tell. What could make it smoke like this?
  2. nfn15037
    nfn15037 Senior Member
    Ring lands are probably broken or at the very least poorly sealing rings.
  3. b16coupe
    anderson, S.C.
    Would that make it smoke out of the valve cover and back of the motor? The lands could be bad but the rings are year old total seals so i don't think they are bad.
  4. b16coupe
    anderson, S.C.
    Yep, you were right. I think the guage was wrong though. it showed 95psi, 100psi, 30psi, 120psi on pistons 1-4 respectively.
