car won't past 3000rpm
Discussion in 'General Tech and Maintenance' started by twotwo, Sep 21, 2006.
  1. twotwo
    twotwo Senior Member
    Hey guys i have a problem the motor won't drive or rev past 3000rpm when it hits it starts to bog and sputter. No cels whatsoever motor is b18c1 in a ek. I thought it might be the fuel so i changed the fuel filter and injectors but no good same prob. Also switch ECU but samething. Any help would be greatly appreciated, thank you and have a nice day!!!
  2. Scorchin Civic
    Scorchin Civic Senior Member
    Irving, TX
    I had the same problem with mine but it was not wanting to go past 5000rpms. Turns out it was my timing, so check to see if you have your timing right.
  3. twotwo
    sorry i took so long to respond......yeah just checked, timing is dead on!!....any other suggestions would be greatly appreciated....thank you and have a nice day!!!
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    its more than likely your distributor it sounds like its in lip home mod just get a new one or borrow one to make sure thats what it is but im perty sure thats it
  5. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    yeah ^^^, it sounds to me that your dizzy is somehow shot.
    Borrow one, switch it to see if that fixes your problem.
