car won't start
twotwo
Hey wassup guys i just got done helping a friend install a JG manifold and a AEM fuel rail on his 2001 GSR.....everything installed and double checked.....so we go to start it up it fires but does not stay on....it will start it up but quickly but dies like 2 seconds afterwards.....im thinking it isn't getting enough fuel so we change back to his stock fuel rail and same problem......also on the fuel pressure regualtor we had to grind it down a bit so it would fit.....the fpr was too long therefore it was hitting the manifold and we couldn't bolt it down......any thoughts on what it could be???.....thank you and have a nice day!!!
i would check the injectors to see if its getting proper fuel. a had a map problem but the car still ran jus like shit. sounds more like a fuel problem to me.
yeah it was map problem.....had the plugs swtiched around.....once again thanks for your help.....
