Car wont start
Discussion in 'HYBRID -> ED-EF / DA' started by WindZC, Sep 21, 2003.
  1. WindZC
    WindZC Junior Member
    Hi I have a Honda Civic HB with a ZC motor and at first my relay wouldnt click the ecu wouldnt start and I have no power at the fuel pump well now I have fixed everything but power at the fuel pump and I cant start my car. Any Ideas what it could be (its a new fuel pump I just put in) still I dunno. I have been doing this swap for the last month and I would just like for it to start please help me if u can. Also after trying to start a couple times would the starter start getting really hot?
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    make sure all your grounds are secure, especially the one at the thermostat housing - this one affects the fuel pump
  3. kingwilly
    kingwilly Senior Member
    arizona
    so it cranks over but wont start?check your timing,well first make sure you got fuel,then i would say get a new dis cap/rotor..check all your wires and fuses
  4. wildbillhatchbac
    wildbillhatchbac the OG VIP
  5. WindZC
    well after I replaced my starter, my fuel pump started magically turning on. It was pretty friggen weird. Let me give u the quick run down this was a DX to a ZC swap tried the whole DX to ZC conversion *IT SUCKS* so I converted my whole car to Si. I removed my DX cabin harness and switched it to Si. then the next thing u know I lost power at the ecu and fuel pump *blew a fuse* replace the fuse and everything comes back but the fuel pump so I stare at my starter as it seems to be growing green mold as I stare hard at it and my friend Mr. Honda-tech is like wow this starter looks really weird bro. *from the DX* so we replace it with the si to learn the si extends much further then the Dx and the next thing u know pissssssss fuel pump comes on after a couple turn overs nothing still *cry* then we disconnect the fuel line to the rail to see if gas comes out. after a couple tries a few drops came out. Thinking to myself hmm this motor demands a little more gas then USDM my friend who also has the ZC swap says you know I have problems starting my car when I am low on gas and I am sure his low on gas is more then a gallon so tomorrow I will grab gas and HOPEFULLY *I really do hope since my Eclipse died yesterday* so hopefully my car will start with a little more gas. But thanks to u guys who responded a lot more helpful then some asswipes from thezcr.com
  6. kingwilly
    arizona
    i have a b16 motor in my crx and im running the factory si fuel pump and it still runs fine and i know my tank is just a little less than a quarter full and the fuel thats in it is anout 5 or 6 months old cuz im still waiting to replace my clutch..sounds to me like you have an electrical problem somwhere,maybe some wires,maybe a couple of your fuses are the wrong amperage for your swap and what did you mean by when your starter was running so was your fuel pump?maybe i misread your post,i am pretty freakin tired
  7. WindZC
    well after adding gas the car will still not start seems like im lacking pressure still
  8. WindZC
    any idea where to start and see if there is a leak or something?
