jdmcivicb18
in the distributor the rotor is not hitting the studs in the distributor cap and sendin the spark to the plugs cause it wont fire up. Any help??????
Originally posted by horsedangler@Oct 17 2003, 10:51 AM
most of the time a rice flush will help this problem!!
ok, this guy just got banned.
where exactly is the coil?
Originally posted by tab@Oct 18 2003, 11:28 PM
It should be mounted on your engine if it is external. It would be the only other wire going into your distributor cap besides the spark plug wires. If you have just the spark plug wires(4 not 5), then it is inside the distributor(internal).
