car wont start
Discussion in 'Accord' started by need2bfaster, Aug 5, 2009.
  1. need2bfaster
    need2bfaster New Member
    pa
    any thoughts on why my car just quit running turns over but wont start my plugs are covered in oil could my rings be bad ??
  2. DESPAIN
    flower mound TX
    is your feul pump kicking on? might be the main relay?
  3. need2bfaster
    pa
    no the fuel pump is kickin on but i have had issues with the main relay.... but reguardless that wouldnt cause the plugs to be drenched in oil would it
  4. DESPAIN
    flower mound TX
    No i dont think it would. Does it smoke like a train? You could do a compression test.
  5. need2bfaster
    pa
    no smoke yea i am going to do a compression test here in the next day or two but when it does decide to start you can smell alot of fuel and it just sputters the shuts right back off ...think the distributor may be bad ??
  6. Hondadude141
    TX
    You plugs are covered in oil? on the tip where the spark is created or on the upper part where the wire connects to the plug.
  7. need2bfaster
    pa
  8. Hondadude141
    TX
    That is why your car isn't starting and staying on, you have valve seals leaking. and you need to get those fixed, but it wont be easy, you are going to have to pull the head apart.
  9. 89y49rexsi
    89y49rexsi New Member
    utah
    i had the same thing happen to me when i first got my b16when you take the valve cover off there are little orings under the sparkplug hole replace then that was my problembut it could very well be from the valve seals as well but i dont see that happening if you never smoked
  10. need2bfaster
    pa
    thanks ill pull the head off soon but isnt it kinda of odd saying if it is the seals for all of them to go at once
  11. Hondadude141
    TX
    eh, it happens, I had it happen in 3 out of the 4 in my accord at the same time.
  12. Hondadude141
    TX
    He said where the spark is created, which means the tip, not the shaft of the plug, only the top part would be soaked if it was the seals that go between the valve cover and the head, the valve stem seals cover the tip of the plug that creates the spark, and it has the possiblity to be the head gasket too
  13. need2bfaster
    pa
    ok well guess il be teraing it apart this weekend to see whats up
  14. johnzy00
    johnzy00 New Member
    if the oil is on the bottom of the plug (were the spark is created) it definatly would not be valve cover seals. Like the person said earlier its prob valve seals or rings if its all 4 and it happened all of a sudden I would def check comp but either way take the head apart do a wet and dry comp check so you can determine main cause thats pretty weird that it happened all of a sudden and NO SMOKE hmmm.
  15. need2bfaster
    pa
    yup no smoke at all kinda jack about it just shutting off but it happens and thanks for every ones thoughts/inputs ill be checking out the compression and tearing the head apart this week
  16. 91civivlx
    91civivlx New Member
    my brother drives a 91 civic lx. 1.5 lt, he was driving it the other day...and it just quit while he was moving down the road. at this point it wont start at all, just cranks and cranks but wont start. we have fuel, spark, but still nothing. the code from the ecu is 16, injection system defective etc...replaced main relay, nothing changed. re checked ecu.... no code since we reset it when changing the main relay. any one have any ideas whats going on here??
  17. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    Start your own thread. I'm sure then someone would be glad to help. Thread-jacking just gets you flamed. especially when its nearly a three month old thread.
  18. 91civivlx
    sorry bout that...new to forum...hence the green horn.....not completely familiar with how to do start a new thread...
