car wont turn over!!!HELP PLEASE!!
Discussion in 'HYBRID -> EG-EK / DC' started by 93delsol-racer392, Aug 15, 2008.
  1. 93delsol-racer392
    93delsol-racer392 New Member
    paso robles, ca
    k so i replaced my timing belt in my 93 civic cx that im in the middle of puttin a jdmb16a in and now the dang thing wont even turn over. i havnt messed with anything since doing the belt except put in my axles cause like i said im doin the swap and that was the last thing it needed now it dont start. does anyone have any ideas all help is greatly appreciated
  2. Spo0led
    Spo0led Got Boost?
    Dover, Nj ..dont visit
    is everything hooked up like wires, dizzy, contections good..double and triple check
  3. 93delsol-racer392
    paso robles, ca
    ya like i said i havnt touched any of that and it started before i did this belt swap. i will tripple check tommro though
  4. Dark93DX
    Dark93DX New Member
    B.C.
    First thing I'd check is the wiring between the battery and the starter. (also just to be sure you could try to check the switch on the clutch pedal since the engine wont crank until the clutch is in, just a thought)
  5. driverunknown
    driverunknown Senior Member
    By wont "turn over" you mean it cranks but doesn't start right? If that is the case then your timing is way off on the belt when you changed it. Make sure you align the cams and the crank pulley :)
    Another thing to check is for your fuse box. maybe one of those fuses is out. Also check for fuel and spark. When was the last time the car had gas in it?
