jimboburgess
Go fast, Go Cheap
Hey everyone,
So i recently put GSR cams into my b16a that i have in a crx. it ran well for a few weeks then i put new iridium plugs and three days later i find it is giving me horrible trhottle response and idling really bad. I pull out the plugs to see that they are thoroughly gummed up with carbon. SO i go put in NGK-r plugs and same problem happens.
I've discussed this with this guy at my auto parts store who ran a similar crx and we've whittled it' down to the timing.
do you guys think that it could be the timing?
He mentioned that i should put a jumper in to prevent the timing from adjust itself back to normal, where do i run that jumper, if it is the timing?
