Carburetors, bitches!
Discussion in 'Auto Multi-Media' started by Battle Pope, Sep 8, 2005.
  1. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    arrrr harharhar
    ...this shit better work. :ph34r:
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    man, you know noone gives a shit about that car....
    J/K.. I hope it works out for ya.
  3. Battle Pope
    I know, that's why I'm gonna make all these posts to piss y'all off! bwahaha
  4. NissanNiNjA2nd
    NissanNiNjA2nd Senior Member
  5. phunky.buddha
    Dallas / Fort Worth, TX
  6. Airjockie
    Airjockie Watanabe Whore!!!
    Meriden, CT, USA
  7. cxjon
    cxjon Senior Member
    man+k+toe
    whats withg the carbs
  8. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
    They have chrome covers, which will allow for much higher CFM's, and at least 40hp......
    No, seriously, hes putting them on his Z.
  9. Battle Pope
    Moral of the story:
    EFI is great when it works. When your wiring looks like a victim of freddy krueger, it's time to take the simpler approach.
  10. NissanNiNjA2nd
    try to tune 3 side draft webers and you will think differently about the "simple approach"
  11. Celerity
    Celerity Well-Known Member
    Tuning 3 ? Clayton had to learn on 4 DGVs. Beat that.
    I learned how to tune them at the Shop (Ferrari shop) try tuning 12 overheads.
    I learned how, but getting it right takes mastery. But with the vacuum gauge you should be all set to get it to run correctly.
  12. Battle Pope
    it's "attached" to the head. Now I just need to make the linkage work, run the lines, and figure out wtf's up with these mechanical chokes. :p
  13. Drake
    Drake Well-Known Member VIP
    Lookin good man. Good luck!
  14. Airjockie
    Meriden, CT, USA
    At least you have air filters.... :blink:
  15. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    o yeah....Very nice.... :worthy:
  16. phyregod
    phyregod !!YTINASNI
    Central Texas
    SOooOoooo.. Here's the big question...
    Was it easier and cheaper to source two carbs, an IM, gaskets, hook up the linkage, tune them, and get em running than it would have been to buy a painless wiring kit and re-wire the car?
    Too late now! ah well, keep us updated.. Cause you know we dont care.. :D
  17. Airjockie
    Meriden, CT, USA
    wires
    :ph34r:
    I did the EFI swap...and it was a bitch...many days to just get the wires done...ask B. And there are still some wires that are not even hooked up in my Z :(
  18. Battle Pope
    Exactly. wiring is a bitch even when it's all there. I've got fuckin' wires missing, cut where they shouldn't be, attached elsewhere. It's a mess.
    So far I have less than 300 bucks into everything for the carbs.
    And Clayton, do you know if these downdrafts are supposed to run a return line? cause I only see 2 fittings on this thing: fuel inlet and vacuum advance.
  19. Airjockie
    Meriden, CT, USA
    if the bowl needles are good...you dont need a return
    I can't remember if mine had one or not.
  20. Battle Pope
    These better be good. They were rebuilt a week and a half ago by a weber guy.
    Here's another one: Do I have to hook the vacuum advance up to one of the carbs, or can it be hooked up to the balance tube?
