CEL 1, 45, 65
Discussion in 'HYBRID -> EG-EK / DC' started by Quick.Silver.C5, Sep 20, 2005.
  1. Quick.Silver.C5
    Quick.Silver.C5 Junior Member
    I am getting three CEL codes - 1, 45 & 65 - the setup is a B18C5 in a '99 DX. The O2 sensors were just replaced. I have tried clearing the codes but haven't had any luck.
    I think it is a wiring issue. Are there any information pages online that might yield specific information about properly wiring the O2 into the system? All of the information I have seen doesn't solve the issue.
    #1 - Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor
    #45 - System Too Lean or Too Rich malfunction in the fuel monitoring systems
    #65 - Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater
    Thanks for your help.
  2. confusatron
    confusatron Senior Member
    Chicago area
    I would replace the sensor first. They're pretty cheap.
  3. SpoonTuNed
    SpoonTuNed Senior Member
    if you wired up your o2's yourself you might of got the two black wires hooked up backwards. those 2 wires specifically go to something, there not just grounds.
