Cel 10 OBD1
Discussion in 'General Tech and Maintenance' started by RoughKnight, Sep 14, 2009.
  1. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
    Yes, here we go. I took a few pictures to help out.
    I'm running a D15B obd1(not 3stage), and code 10 keeps poping up. I'm pretty sure I have the right wires plugged. Also, where is the EVAP plug for the sensor? It's just dangling there...
    Pics are in attachments. This is getting ridiculous, ever since I did this swap its been problem after fucking problem. This thread is on instant notification so I will answer back almost immediately.
    It runs rich, and the tuner will NOT take my $450 to chip and tune my car until the cels are all gone. Lose lose situation so far. :(
  2. RoughKnight
    Ottawa, Ont
    Bump for shiny engine bay pic
  3. tjscivic
    tjscivic New Member
    I have been reading around and I came up reset the ecu if that dont work check the voltage at the harness side and if that dont work replace the sensor.
  4. RoughKnight
    Ottawa, Ont
    Hmm...I'll show the Honda Manual to my mechanic and have him check the voltage from d15 to d22 and the other one, can't remember atm. It's just that I want to go boost, and the tuner will NOT let me tune the car for N/A (next year going turbo) for my 150hp goal if the ecu is still showing check engine lights. Is there any way to clean the sensor? Its the one adjacent to the drivers side, with two screws holding it and you have to plug it in facing directly up?
  5. reikoshea
    Dallas, TX
    you've got the wires plugged in wrong. that one that's just dangling (red and yellow) is for your IAT sensor. which is what's throwing your code. fix that and all should be well.
  6. RoughKnight
    Ottawa, Ont
    I tried replacing both into the slot where the one is now, and reset the ecu. Both dont work. I was researching and found out that the one with the SOLID red wire (the dangling one) is for my EVAP.
    brand new iat sensor - Honda-Tech
    Quote:
    2P IAT = Red/Yel and Grn/Wht
    2P IACV = Yel/Blk and Grn/Wht
    2P Purge Solenoid = Yel/Blk and Red
    3P TPS = Yel/Wht, Red/Blu, and Grn/Wht
    So what now?
  7. reikoshea
    Dallas, TX
    well you could do this:
    pull the sensor. see how many ohm's its passing at room temperature (cold). Then use a hair drier on it for a minute or so. Test again. See you manual for acceptable readings. If they are out of range then the sensor is bad. If they are in range then the wiring is likely bad.
  8. RoughKnight
    Ottawa, Ont
    Okay finally somebody on the right track,
    In the morning, when I just fresh start the car, the cel comes on. After the car warms up to operating temp completely, the light goes away if I turn off/turn on the car. So i'm guessing thats your hairdryer trick. Now is it faulty? Or is the wiring faulty?
  9. reikoshea
    Dallas, TX
    its probably giving a bad reading in cold state (bad reading meaning reading outside of normal resistance).
  10. RoughKnight
    Ottawa, Ont
    So does it need to be replaced? Or are my wires still messed up?
  11. reikoshea
    Dallas, TX
  12. RoughKnight
    Ottawa, Ont
  13. RoughKnight
    Ottawa, Ont
    while we're on the subject
    where does the evap plug go? I dont think i have the sensor for it or I need it cause its' not throwing a code
  14. reikoshea
    Dallas, TX
    I'd say RTFM for where the plug goes. As long as there's no CEL and you're not in cali it doesn't REALLY matter. just hope it doesn't end up in a ghost limp mode.
  15. RoughKnight
    Ottawa, Ont
    RTFM?
    Ravish The Fucking Manual?
    And ghost limp mode?
  16. reikoshea
    Dallas, TX
    limp mode without a CEL. i made up the term
  17. RoughKnight
    Ottawa, Ont
    hmm
    does the old one off my d15b7 work? is there even one on that engine? I jsut went to the mechanics today and i saw he still has it there, maybe I could switch it up?
