cel check issue
Discussion in 'ECU's, Electronics, and Tuning' started by Dark91zc, Jun 23, 2005.
  1. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    how do i check what code my ecu is throwing when a 91 civic has stock obd-0 wiring with a obd-1 jumper harness and a 99-00 ex civic gauge cluster?? i know one code is the 4 wire o2 sensor. as soon as i start my car the check engine light comes on :( i am trying to fix this
    lance
  2. pissedoffsol
    if you're using an obd1 ecu (along with the obd1 distributor, etc), you're using obd1 error codes.
    i don't see what the cluster has to do with it.... it shouldn't matter.
    but now that i'm thinking.... is there even a jumper service port in the EF's??
  3. Dark91zc
    Corona,CA
    not that i know of :(
  4. ^crx^
    ^crx^ Senior Member
