Cel code 3 wiring issue
Discussion in 'General Tech and Maintenance' started by darren1984, Jan 18, 2009.
  1. darren1984
    darren1984 New Member
    Hi lads, Tried to search but couldnt find anything relating to my issue,
    I have an ej2 coupe with a b16 swap, im getting a cel code 3 flashing up, I have looked over the wiring going to the map sensor,the wires that are going to my map sensor are pink/wht, yellow/green and green/blue, its an obd1 ecu, the wries are cut and joined over at the passenger side in a big harness and 3 seperate wires run to the map sensor, bit of a botch job, but are these the correct wires? and why the bloody hell cant i make the cel go away?
    Thanks for the help!
