I<3myhonda
as title says, i just finished up my mini-me swap on my 91' Hatch (std)/d16z6/d15b2. ok well my ? is: i was throwing cel code 9 CYP, so i double, triple check my wiring, after doing my searching and wire checking i s... so i tapped it into b12 which i already had the other CYP wire connected. reset the ecu and vala nomo cel. so i would like someone to confirm that this will not harm anything. it seems to be running fine and cel does not come on, i check and made sure there was not a cel and that it was working. i figured since they are both the same sensor it would be safe to do so. can someone tell me if im wrong? if someone could respond asap that would be awesome because i surely dont want to fry my ecu or my dizzy after i just got her done and running Please and Thanks in advance to any response
