Cel Codes: 4 What Can I Do To Fix It..
Discussion in 'HYBRID -> ED-EF / DA' started by bossman032, May 3, 2003.
  1. bossman032
    bossman032 Senior Member
    I have a OBD0-OBD1 ECU Harness and Engine Harness.
    Car starts and everything kool.
    but I cant rev my car past 3.5rpm.
    Today I Fixed my ECU harness now its giving me codes 4,7.
    Code:7 I know how to fix already because.
    I need help on how to fix code 4 CKP...?
    please help out if you can!!!
  2. bossman032
    habah
    anyone :spin:
    piss me off :rolleyes:
  3. Civic_88ls
    Civic_88ls Senior Member
    everett, wasington
    check ur distributor cap. it might have moisture in it. that has happened to me a couple times.
  4. guitard
    guitard New Member
    Lynnwood, Washington
    i have code4 too in a pr3 ecu. not sure but i think its crank angle. but i can drive fine, hit vtec n all. wtf?
  5. LateApex31
    LateApex31 New Member
    It is a VR (magnetic) sensor inside the distributor. Either the wire isn't connected properly, there is damage to the toothed wheel, or there is too large a gap between the sensor and the toothed wheel.
