CEL help....
what it looks like to me is code 10, which is the IAT sensor..i may be wrong...so i just wanna get a second opinion on that code(from the vid)...or is it code 20...see i dont know...first time checking CEL code....im a noob at this
PLEASE HELP ME
doesnt look like its showing a code if you ask me...mine stays off for a few seconds before it starts blinking. might want to make sure you have the juper wire/pin in the right holes. sometimes i put it in the lock wholes insted of with the leads. its an easy mistake to make.
so i make a circuit between the blue and brown wires, right...??im a noob at the ecu thing
[post=557558]Quoted post[/post]​
yes, and then the CEL will start blinking with the appropriate code.
Yea if you want to make sure, unplug your o2 sensor, start your car, then re do the test.
You will now have another code!
I woulda unplugged the IAT or something....its right there and all it requires is popping the hood.
which one of these plugs do i use...???
