calmfornow
System Failure Racing
ok, so i swaped a jdm h22a into my 91 accord. the motor is a 93, i did the whole engine and trans swap and my own wire job. I also have the H22a p13 ecu in it. my two codes that came up were the knock sensor and the egr lift sensor. i wired up the knock sensor and the egr lift sensor code went away but the knock sensor code is still there. when i start it up the CEL stays off for about 5-10 min. depending on the engine heat. i checked where i wired up the knock sensor and it is correct PIN D3 CEL stands for check engine light for some people who are not knowing what im talking about
help will be appriciated'
thanks
thanks
