CEL on 97 civic dx
Discussion in 'HYBRID -> EG-EK / DC' started by reckedracing, Jan 6, 2006.
  1. reckedracing
    reckedracing TTIWWOP VIP
    NY
    any suggestions?
    is this located in the actual dizzy?
  2. DelSlo
    DelSlo Senior Member
    well it depends what the code is in particular.... in obd1 92-95 all cam and crank sensors were in the dizzy, if you were getting this code on an obd 1, youd be replacing the dizzy. if your car is obd2, which is what im assuming, it uses a crank sensor AT THE CRANKSHAFT, not inside the distributor, so your code could be saying its not gettin signal from the crank sensor , they arent too bad to change if thats the case.
    more info could help your situation! :)
  3. reckedracing
    NY
    oh i see
    car is a 1997 civic...
    as stated in the title...
    i recently did the timing belt and don't recall seeing a crank sensor on it...?
    any ideas?
  4. reckedracing
    NY
    so update
    my sister went to auto zone and they pulled a "misfire" code and advised her to change cap, plugs and wires...
    then it won;t start at all
    so she got a new dizzy
    still no start
    new rotor and still no start
    when it did start the computer light was solidly on and then flashing while it was running... the only time i have seen this is when i left the code jumper hooked up on my P28, started the car and the CEL flashed while it was running...
    so is her computer shot?
    i was also told to look into the blue box relay on the kick panel and to check the internal coil/make sure the spring was all the way in the cap and making correct contact...
  5. reckedracing
    NY
    come on, no one knows these OBD2's?
  6. leckey73
    leckey73 Junior Member
    I MIGHT HAVE THE SAME PROBLEM
  7. triniDEMON
    triniDEMON Member
    NEED MORE INFO
    HOW DOES THE CAR SOUND WHEN U START IT B4 JUMPING THE CONNECTOR AND THEN AFTER
    WHAT KIND OF MOTOR(AND SWAPS)
    HAD THIS PROBLEM WHICH CAME INTO MY SHOP.......IT TURNED OUT TO BE TIMING WAS WAY OFF(TENSIONER WAS REALLY LOOSE)
    HOW LONG DID IT HAPPEN AFTER U DID THE TIMING WHEN THIS PROBLEM OCCURED
