changed gasket and still losing oil
Discussion in 'General Tech and Maintenance' started by Periculum, Nov 9, 2004.
  1. Periculum
    Periculum Senior Member
    Martinez, GA
    I changed the valve cover gasket a few days ago and im still getting oil that is seeping through between the valve cover and block. did I miss something. Its a rubber gasket, so it said not to use any adhesive. I cleaned off all the surfaces before I put it on.
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    you might have a crack in the valve cover, or the head, take a closer look, and be sure to lube the corners by the cam gears and distributor on the gasket.
  3. webink_EK9
    webink_EK9 Senior Member
    Your cover may be warped also.
  4. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    use red hight temp i do and it dosn't leak
  5. b204dr
    b204dr Senior Member
    Minnesota
    yea use some hondabond or some thing to seal..
  6. Periculum
    Martinez, GA
    I took it off and cleaned it again to make sure. seems some old oil was still there when I put the gasket on, giving it a way out. The car seems to perform a little better and im getting a little better mileage so i think it did the trick. Ill look into a sealant though, can't hurt, right?
