Changing a/c compressor
Discussion in 'Accord' started by 92CHB, Sep 6, 2006.
  1. 92CHB
    92CHB Senior Member
    Easthampton, MA
    I am gonna change out a friends ac compressor on his 1995 accord and i was reading the paper work they sent with the new compressor and it says to fill the compressor first with oil..... how would i do that? I have a full recharge kit with the aresol cans and trigger/gun thing. I was planning on just following the instructions with the kit. I just wanna make sure i dont f*ck anything up. Thanks guys
  2. rlyons
    rlyons New Member
    You need to get the proper oil for the freon you are using and pour it into the compressor susction port. The amount is different in each case but it should tell you how much in the directions. You can buy the oil at AutoZone or most parts stores.
  3. 92CHB
    92CHB Senior Member
    Easthampton, MA
    Thanks i'll look into that, also the new ac compressor has no "directions" anyone know the amount to put in? :)
  4. dens_310
    dens_310 New Member
    <<<<not a big help
    good luck
