you can use the same plug to check the codes. it just flashes on the cluster instead of on the ecu. just leave your check engine wire on the conversion harness alone. thats what I did on mine
did you get the sub harness? I also suggest getting the dist adapters also with your conversion kit.
yes you need a obd1 dist, p28/p30 ecu, and 4 wire o2 sensor
