Changing vtec on Pr3 mugen chip
Discussion in 'ECU's, Electronics, and Tuning' started by BigBoy, May 21, 2005.
  1. BigBoy
    BigBoy Senior Member
    cali 818
    The vtec hits at 4400 and is annoying when driving around 75 on the freeway, i go in and out of vtec. Is the only way to change the vtec point is to get a vafc?
    Is there a specific point to set the vtec for max power?
    Im also considering converting to obd1 and going hondata.
    I currently run a b16 with bolt ons and stage2 cams.
  2. phunky.buddha
    Dallas / Fort Worth, TX
    If you're chipped, you can have the program read, changed, then burned back to a new chip. You can also get a VAFC and raise the VTEC point- just remember that your fuel maps do NOT change when you move VTEC, so you'll have to get the car tuned somewhere to match.
  3. kenji
    kenji Junior Member
    I can send you another chip with either a 5300 or 5500 VTEC switchover.
    Email me at kenji211@tampabay.rr.com for more info.
    -kenji
