Cheap Suspension Waste of $$$ ???
Discussion in 'Civic and del Sol - EG and EK' started by CAFROG, Jun 4, 2009.
  1. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    My '92 hatch suspension is very basic. I have Neuspeed race springs and KYB shocks...and camber kits.
    I am looking into getting a little more performance out of the suspension and was just going to start with a strut tower bar but keep seeing these cheap combo kits. The few people I talked to says it'll be a big improvement but I'm skeptical
    I always thought welded or one piece designs were optimal but thought I'd get some feed back from you guys on the link below:
    92 93 94 95 Civic EG EH EJ Front Rear Strut Bar Combo:eBay Motors (item 290320393585 end time Jun-04-09 00:22:37 PDT)
  2. !JDM_EF-9!
    !JDM_EF-9! I'm just EF'n..
    cailfornia
    with ebay..
    all I gotta say is you get wat you pay for basically..
    but my cuzin got a set of strut bars from ebay and they turned out pretty good so go for it..
  3. poloboy4
    poloboy4 New Member
    washington
    :D get what i have ttein electronic damping force controller awsome set up :D 2000 civic si handles like a beast! :)
  4. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    a solid bar like the neuspeed one is the best bet, but the cheap ebay bars are better than nothing. i noticed a difference in handling, particularly when i put the rear on.
  5. TurboMirage
    if you get a hinged bar, bolt it snug to the car, unbolt it and have the hinges welded. BAM! cheap solid bar.
  6. eg6sir
    solid bar > hinged..... and i agree.. Neuspeed 4pt bar is the best bet up front.. it attaches to the UCA rather than the shock tower
  7. TurboRex90
    TurboRex90 Golden EG
    Maryland
    Not everything on ebay is cheap.
    I got a full set of Skunk 2 pro S series coilovers for 600$ free shipping.
    Like 200$ cheaper then they retail for, and were authentic with skunk 2 warranty card etc.
    You just need to know what to look for, and how to look for it.
  8. INJEN78
    INJEN78 HS LEGEND
    OHIO
    i agree with turbomirage...
    but if you do not want to weld them the ebay ones work just as well...
    hell skunk2,tanabe,tenzo and all them i think have hinged ones
  9. CAFROG
    NOR-CAL
    Ya....most are hinged. I always thought neuspeed was the way to go....or teg type r b/c they're all solid like a rock.
    I figure for $70 shipped....four pieces...better then nothing.
    Thanks for the input guys. Just wanted some feedback....glad to know someone has seen the set up on something.
  10. phyregod
    phyregod !!YTINASNI
    Central Texas
    neuspeed bars ftw, IF you can find them. i think neuspeed stopped producing them all together, which sucks.
    But, a bigger bang for your buck (and way way more noticeable) that noone has mentioned: Sway bars. New, bigger, beefier sway bars with nice firm bushings will do wonders for a suspension.
  11. BrutalB83
    Rochester Hills, MI
    He already has shocks and springs. He's asking about which strut tower bars to get...
  12. INJEN78
    INJEN78 HS LEGEND
    OHIO
    get the upper/lower/front/rear kit..
    you an also get the b/c pillar and have a rigid as fuck chassis
  13. Briansol
    your springs/shocks are 21324123 times better than those egay coil overs.
    strut tower bars are a waste of money imo.
    you want handling? get a huge rear sway and learn how to drive with some over steer from a tail-happy fwd car :)
  14. !JDM_EF-9!
    cailfornia
    exactly my point..
    thats still your 600 bucks over his 60 or 70 dollar combo strut bars!
  15. CAFROG
    NOR-CAL
    I figure its not a bad buy for $70.
    They say no mod's needed to install...so it should bolt up with little effort.
    I just want to be able to corner a little better....it's not like I expect to pull 1.3 G's on the skid pad. I have 14" Del Sols and my 185-60 series tires can only handle so much anyways.
  16. eg6sir
    hope they work out... i dont think they'll do much though
  17. CAFROG
    NOR-CAL
    Anyone tried them?
    If they flex a lot (b/c its aluminum) then it would be silly.
    I might just get an old teggy upper strut, clean and paint it (looks clean and stock)
    And do the lower sway bars later (like was stated by "B")
    B:
    What rear sway bar would you recommend?
  18. eg6sir
    Type R .. you'll need a subframe brace like the ASR one though.. to prevent tearout
  19. TurboRex90
    Maryland
    Oh im not saying its the price, i was only making a point that ebay isnt always knock off junk products. Sometime you catch legit deals.
  20. !JDM_EF-9!
    cailfornia
    :werd:
